I bought the AMD kit (mainboard, ram, wifi card) and installed it to the cooler master case. although the primary location of use has Ethernet cable for internet I would like to be able to use it in other rooms in the house. if I install the wifi card to the mainboard will it operate by itself or doI need to buy the $14 antenna kit for the framework 13?
You will need an antenna for the wifi card. While Framework’s antenna will work, you can also purchase an antenna kit from Amazon.
