Does the DisplayPort Expansion Card work on any side?
Or does it only work on the top ports? I’m assuming it was designed to work on any of the ports for Framework 13 but I’ve realized that my DisplayPort card is only working on the top ports only. Is this a mainboard issue?
Check the image in Expansion Card Functionality on Framework Laptop 13 (AMD Ryzen™ 7040 Series)
as the guy before me said, if you got an intel all should work, on AMD the front left one is not working and only the two ports behind are working with USB4
Sorry, I forgot to mention I’m using the AMD board.
I wish I had known about that chart earlier! Thank you!
