Dual Monitor and 2560x1600 on built in screen
Anyone know if it’s possible to get the “2k” resolution on laptop screen when using 2 monitors? It lets me set it when using 0 or 1 external monitor but as soon as I connect the second monitor, the highest resolution I can pick is the 1920x1200.
Have you got the dGPU?
Yes, I do
I fixed the issue (accidentally). I was troubleshooting “meta” key not working in Citrix VDI and found out Citrix doesn’t support Wayland. When I disabled Wayland, the “meta” key behavior was fixed but also I got 2k resolution back on laptop screen when my 2 monitors where connected.
