Dual USB-C Expansion Card
Looks like there’s physically enough face for 2 x USB-C so it depends upon the layout inside for protocols.
yes, but each USB-C plug is larger than a USB-C, right?
Has the rubber bits around it so you can actually grab them
Plenty of room and especially as I push and pull by gripping the wide sides, the top and bottom.
Dual
that’s great.
I just wanted to say I’m also interested in buying one of these. Need more ports! I assume it won’t be power-compatible, but that’s fine for me. Just looking for data. Right now the plug I would replace with this is plugged into a USB hub.
