Ah, yes. I forgot about that. Though, I think people asking about USB-PD are likely talking about charging the laptop.
Nope, saw that, and while itād be a nice-to-have, definitely not much of a priority for myself.
Are you going to be releasing the full (kicad?) PCB + schematic files? (as in not just the screenshotā¦) I would love to have a cheap one of these in my framework laptop!
And I would be happy to buy within the EU ![]()
Any updates for the expansion card?
Also interested in this ā Iād love to get one of these for my laptop so I can connect my mouse and keyboard!
83 posts were split to a new topic: Josh Cookās dual USB-C expansion card
Hello folks,
Sorry, I have been absent for a while due to various reasons, one of them is having other hobbies too
. This project takes way more effort than I initially thought and I might not have the time, knowledge and resources to make this expansion card an actual product
. Thanks for all your support and interest in this project it has been quite fun so far and Iāve learned a lot designing this
I promised to make the design files public tho, so everyone interested can have a look (and most likely improve it), so the time invested may have some benefit for the community and probably someone can make a product or small production run out of it. Before shelling out 1000s of units Iād recommend building another prototype and run some compliance testing, this is not a production ready design.
The design files are uploaded here: glx-seven/dual-c_expansioncard: This is a prototype of a dual USB-C expansioncard for the Framework-Laptop (github.com)
I might come back to this project and develop it further but I donāt have concrete plans or a timeline. In the meantime maybe someone else has interest in having a look or taking it further
. Thank you for your service. Good luck on your next project.
On the bright side, it seems weāll eventually get Josh Cookās version of the expansion card in addition of this oneās schematics.
Oh, this is interesting. Havenāt followed this one, just Josh Cookās.
Any thoughts on doing a group order of just the PCBs? Iād get a couple, and 3D print up my own cases for them. Iām sure some folks in Joshās thread and this thread might be interested as well.
What are the capabilities? Full 3.2g2 10Gbps speeds on both ports? Any USB-PD?
The ports are both 5GBit, there is a PD controller but it only requests 5V/3A from the laptop so it can provide 5V/1.5A to both ports, charging is not possible.
āJustā ordering the boards is not as simple as it seems, thatās part of why I canāt continue here (without immense effort).
Also Iām not sure if these can be reliably manufactured for a reasonable price, these are loaded with parts on both sides and the host connector is (I guess) not standard pick-and-place. Also the parts go quite close to the edges of the board, so for my understanding not too great from a DFM perspective.
I did hand assemble the prototype but that took quite a while (but double sided reflow worked better than expected).
Side-note, a friend of mine (that has nothing to do with electronics) said āhow difficult can that be, look at these sandwiched iPhone logic boardsā. Well yes you can probably do it but not for reasonable costs in like one-off volumes since your standard-assembly line can probably not handle that.
Ah, too bad about the chip and close to the edges. Yeah, thatās an issue from DFM. And had assembled reflow, yikes. Thatās a lot of work.
And LOL, āhow hard can it beā. Right.
There are 10G capable and native USB-C hub ICs available from microchip but they have substantially larger packages so Iād say they are even tougher to implement, thatās why I chose the one I got. Thereās also a VIA chip that can apparently handle one PD charging port but it seems you canāt just buy that. Also youād have to manage the 20V (or whatever your charger provides) to 5V for the other port plus 3.3V and 1.2V for the USB3 part. Unless you want to stack a few boards on top of each other I guess youāll quickly run out of space.
There might be integrated solutions for that but resources for these seem to be impossible to obtain for non-businesses.
Thanks for putting as much time and effort into this as you did! I was getting more and more excited as I read along all the updates since I last checked in on this project, I hope someone else is able to take it across the finish line. Good luck in your other hobbies and projects!
you realize the plug spacing wonāt actually let you plug in 2 things at once, right?
If only the input modules are a tad wider ⦠or a tad narrower, so you can have 8 rather than 6.
But the full size SD module is here, so I guess it is the perfect size.
I just wanted to say Iām also interested in buying one of these. Need more ports! I assume it wonāt be power-compatible, but thatās fine for me. Just looking for data. Right now the plug I would replace with this is plugged into a USB hub.
hello, I wanted to know any new about this expansion card! I would love to but a dual USB C or dual USB A!
and something like usb A for data and USB C for ideally fully featured(charging and display)? or at least charging?
