In other words, would removing the RTS battery and all that effectively clear the CMOS?
Thanks!
Thanks!
For 11th and 12th gen, a mainboard reset is performed via removing the CMOS battery. For other gens, they don’t come with a CMOS battery by default but their mainboard reset procedure is effectively the same as a CMOS reset.
OP’s question was not about the procedure. It was on “Is mainboard reset equivalent to CMOS reset?” or what does a mainboard reset really mean. The later part of your post answered the question.
Ahhh got it! Is there a faster way to clear CMOS than to do the whole reset procedure on the 11th gen models, or is that it?
OP didn’t originally specify which gen they had that is why I had to mention both options.
Guess I saw the question differently as it was “mainboard reset” aftermath related, which is the irrelevant to the generation of the mainboard and the procedure it self. It’s a post-procedure execution expectation / level set matter. But maybe my view of it was too narrow.
