In general I agree, however I do have some comments:
Regardless of how Intel obtained an advantage, an advantage is an advantage. So if Intel does have an advantage in value that is an argument in favor of buying Intel CPUs.
Some of the reasons that article gives for Intel having an advantage are “Raptor Lake is backward compatible with previous-gen 600-series boards after a firmware update, which can save you some serious cash.” and “Intel gives you the choice of selecting either DDR4 or DDR5 memory, while AMD only supports pricey DDR5.”
AMD is at the beginning of a motherboard socket cycle while Intel is near the end. When a company is at the beginning of a motherboard socket cycle the motherboards tend to be more expensive, however there is a decent chance that they will still be able to be used in a couple years if you want to upgrade. When a company is at the beginning of a motherboard socket cycle the motherboards tend to be cheaper, but next time you want to upgrade you’ll need a new motherboard. There are pros and cons to both and I wouldn’t say either option is superior. Although this doesn’t apply when it comes to laptops so talking about desktop motherboards is useless when debating what CPU should be used in a laptop.
As for the statements about DDR5, those are mostly outdated. DDR5 prices have dropped dramatically in 2023 and Intel has announced CPUs that require DDR5 (which if they’re penalizing AMD for means they should also start penalizing Intel). Also, DDR5 brings massive improvements to iGPU performance, which in a laptop can help even if you do have a dGPU (since ideally the dGPU should be disabled whenever possible to save battery life).
Lastly, if someone does want to be at the end of a motherboard socket cycle (for cheaper motherboards) and use DDR4 (for cheaper ram), there’s nothing wrong with using a previous generation CPU. The Ryzen 5000 series has pretty amazing bang for your buck, especially the 5800X3D.
I agree that the AMD is at a disadvantage due to software being optimized for Intel, however many reviews have shown AMD trading blows with Intel in many applications and I disagree that it is a clear win for Intel.
Also, the graphs in that section of the article do not show any Ryzen 7000 series CPUs. That, combined with the fact that the comments on the article have timestamps indicating they were from 3 years before the article was supposedly posted and the fact that they in one spot say AMD uses 7 nm (Ryzen 7000 uses a mix of 5 nm and 6 nm on desktop and 4 nm on laptop), leads me to believe that the article may be an old article updated to mention new CPUs rather than an up-to-date article.
That article does not even mention Thunderbolt, however they do again mention DDR4 vs DDR5 in this section, which for the reasons I listed above aren’t really a strong argument in favor of Intel anymore.
