They’re notoriously stiff.
When I travel, I’m at a different hotel basically every day and working on the train in between on batteries. So I’d end up having to insert and remove it quite frequently.
I’m sure some will be, given the tolerance in manufacture. MIne’s an batch 8 11Gen and has always been fine.
Is it difficult sliding them out and/or is the button not easily pressed or maybe disengaging clearly.
I mean, if they slide in easily then there is likely a problem with the button not disengaging well enough.
It’s the same as in the videos in that link. They don’t slide out easily. It takes a lot of force to get them out initially.
