Hi Everyone,
I wondered if anyone could measure the exact dimensions of the Display for me. Not the outline of the frame, but the real measures. I can’t find anything but the the pixels or the frame dimensions.
Thanks very much in advance
Sam
Hi Everyone,
Sam
Hi welcome.
if you have done some research you may have found
Weight: 412.2g Dimensions: 297mmx 9mm x 229 Width:
What are you looking for it has been mentioned in numerous posts
Try reading the specs
hi Amoun,
thanks for your quick reply. Unfortunately i think you should properly read what i wrote
I dont need the dimensions of the frame (which is what you wrote) and I dont need the pixels. of course i found both those numbers. I need the dimensions of the viewable part of the display. The actual display so to say.
thanks a lot again and have a nice evening (or day or wherever you are from)
I didn’t write the dimensions I directed you to link where you can read the display dimensions, which is what you asked for ??
The glass on mine is 288 x 192
