Expansion slots
Hi guys. Before I pre order this laptop. Does it come with expansion modules or do I have to buy them.
You have to add the expansion modules when configuring your order.
Expansion Cards are the small parts that slot into the 6 modular slots along the side of the laptop to provide ports.
Expansion Bay Modules are the large parts that slide into the single large modular slot at the back of the laptop to allow for a cooling and an optional GPU (or potentially other uses in the future).
It does not come with Expansion Cards, however there are options to add those when you buy the laptop.
It does come with a blank Expansion Bay Module by default, however when buying it gives an option to get a module with a GPU if you want.
