4:4:4!
Thanks again Kyle
Seems like the best solution is for @nrp or support confirm the bandwidth available on the FW16 as the documentation is unclear, and further so when you consider the language used on the DP expansion card.
Having issues getting anything over 4K 60 on my LG G2 OLED
120Hz, HDR & VRR aren’t available ![]()
Using these items:
Any help is appreciated, also I’m in the UK so if I need a dongle I need to be able to source it.
It’s a configuration issue, use this config on AMD → Settings → Display:
Color depth: 10 bpc / 12 bpc
Pixel format: YCbCr 4:2:2 / 4:2:0
Max refresh rate: 120hz
Don’t forget to activate HDR on Windows 11 Configuration → System → Display
I don’t know why but 144hz is not working on any configuration I had test, not even 1080p without HDR.
Thanks mate! I thought I must be missing something and this fixed things nicely for my FW 13 AMD.
