External Display (only) Flickering Constantly
Having issues where the Framework 13 when plugged into an external display, through the official HDMI expansion card, flickers.
It also flickers when plugged into other USB to HDMI adapters I have (Apple USB 3.1 USB-C to HDMI).
The cable and monitor are fine, as other devices when plugged in do not exhibit this behavior (tried 4k60 output from an iPad Pro and another desktop computer RTX3060, no issues).
Changing resolution or refresh rate does not affect the frequency or duration of the flickering.
The laptop display never flickers.
Here is a video of the issue: https://www.youtube.com/watch?v=RO1ruv1Zeh0
There is no USB disconnect noise or sound to indicate the expansion card is dropping out. It does this regardless of which port the expansion card is in.
I have tried several different Intel Graphics Drivers to try and see if that was an issue with no change.
  • Windows 11
  • Framework 13 12th Gen (3.08 BIOS beta)
EDIT: With some further testing, it seems that the stability gets worse when I try to run some sort of program that requires 3d graphics rendering. Using the HDMI into the Apple USB-C to HDMI adapter, I can get a relatively stable desktop until I try to run a 3D application.
I can never get a stable desktop with the Framework USB-C to HDMI adapter.
See follow up video: https://www.youtube.com/watch?v=WFh2q1rKopI - Starts with Framework HDMI adapter, then plug into the Apple adapter which works until I boot into a 3D application (skip ahead while I wait for 3d mark to boot). Then I show the adapter, cable into an iPad pro working fine at 2160p 60hz.
Resolved by uninstalling Intel Graphics Driver in Device Manager then using Windows Update to install an older version.
Sadly, not an ideal solution when Intel is creating very frequent, new drivers with game updates. Will have to resign myself to the fact this is not a gaming machine.
My fiancee just received her Framework 13 13th gen laptop. Upon plugging in her external HDMI monitor she was experiencing the same flickering. I was about to follow your instructions for uninstalling the graphics driver, but I figured I’d have it look for an update before uninstalling. An updated installed and so far the video output is stable.
I wanted to reply to confirm we experienced the same issue and it definitely seemed to be an Intel Graphics Driver issue. Updating the driver fixed the problem for us.
I also started have this issue recently with a Framework 13 11th gen laptop: An external monitor connected via HDMI will flicker on/off (as in the entire screen goes black, then comes back, once every few seconds). It does not happen with USB-C. The issue is noticeably worse when the AC adapter is plugged in. On battery it still occurs but far less frequently. Adjusting the screen resolution, refresh rate, performance settings when on battery/power, and other settings in the Intel Graphics Command Center did not help. I have the latest BIOS (3.24) from Framework.
Oh, I’m running Windows 11 by the way… I’m going to try downgrading from 7082 to 7076 (oldest available from Intel’s website, as of writing). If that doesn’t work then I will try installing the version from Framework’s driver bundle.
Issue still present with 7076…
Going to try installing the driver bundle (Framework_Laptop_13_11th_Gen_Intel_Core_driver_bundle_W11__2024_06_25.exe) - I had to first uninstall the device and driver via the device manager
Still happens even with the old driver! Maybe it’s because my battery is getting old? I’m going to give up and just use USB-C :cry:
