Overwhelmed by curiosity, I bought a Baseus 140W charger. I think I’m seeing two things here, with PPD in performance mode:
As described in the thread by others, in gaming workloads, for some reason, most 140W chargers (but not the Baseus charger) don’t provide a steady high wattage when the battery’s charged. My AOHi charger can provide a roughly 125W stably when the battery is charging, going by a USB meter, but once my battery hits 80% (“full” from the BIOS setting), wattage starts fluctuating, with low frame rates. So, because of some kind of USB PD negotiation failure, or something (maybe the charger’s too slow to modify its power delivery on the fly), frame rates are lower than they should be, here.
The Baseus charger provides a steady 125W or so during gaming even when the battery is charged, but then, gaming performance is very uneven. The average framerate that Steam reports looks about right, but gameplay feels terrible, like the laptop won’t draw from battery as needed so framerates are constantly dipping. So even without the wattage fluctuations, the framerate dips and is uneven, as the laptop fails to pull power from the battery (as far as I can tell), even in performance mode.
With either charger, the framerate feels fine if I unplug the charger and run off the battery alone, or if I downgrade to a 100W port.
# dmidecode -t bios
# dmidecode 3.6
Getting SMBIOS data from sysfs.
SMBIOS 3.6.0 present.
Handle 0x0000, DMI type 0, 26 bytes
BIOS Information
Vendor: INSYDE Corp.
Version: 03.03
Release Date: 03/27/2024
So, in summary: yeah, bump, +1, what everyone else already said.
