Hi, I was wondering if anybody was experiencing the same issue: on my amd 7840u framework laptop 13, I pretty consistently get a hard freeze (laptop completely unresponsive, need to hold down power button to reboot), after, I’m pretty sure, using hibernate. Although It doesn’t freeze immediately, it might take a minute or 10 minutes, so I’m not a 100% sure what causes it. Looking at logs it seems to be gpu driver issue but I’m no expert.
I’ve had the same issue on both debian (kernel 7.1.8) and fedora ( 7.1.10), both using a swap partition and a swap file.
Has anyone experienced anything similar?
Fedora Workation
Which release version?
Fedora 44
Which kernel are you using?
Linux 7.1.10-200.fc44.x86_64
3.20
AMD 7840u
août 31 12:32:20 fedora systemd-logind[1018]: The system will hibernate now!
août 31 12:32:20 fedora ModemManager[1065]: <msg> [sleep-monitor-systemd] system is about to suspend
août 31 12:32:21 fedora systemd[1]: Starting systemd-hibernate.service - System Hibernate...
août 31 12:32:21 fedora systemd-sleep[154850]: Performing sleep operation 'hibernate'...
août 31 12:32:21 fedora kernel: PM: hibernation: hibernation entry
août 31 14:34:30 fedora kernel: PM: hibernation: Marking nosave pages: [mem 0x00000000-0x00000fff]
août 31 14:34:30 fedora kernel: PM: hibernation: Marking nosave pages: [mem 0x0009f000-0x000fffff]
août 31 14:34:30 fedora kernel: PM: hibernation: Marking nosave pages: [mem 0x09b00000-0x09dfffff]
août 31 14:34:30 fedora kernel: PM: hibernation: Marking nosave pages: [mem 0x09f00000-0x09f3bfff]
août 31 14:34:30 fedora systemd-sleep[154850]: System returned from sleep operation 'hibernate'.
août 31 14:34:30 fedora kernel: PM: hibernation: Marking nosave pages: [mem 0x49b50000-0x4bd4ffff]
août 31 14:34:30 fedora kernel: PM: hibernation: Marking nosave pages: [mem 0x4bd69000-0x4bd6cfff]
août 31 14:34:30 fedora kernel: PM: hibernation: Marking nosave pages: [mem 0x4bd6f000-0x4bd6ffff]
août 31 14:34:30 fedora kernel: PM: hibernation: Marking nosave pages: [mem 0x52f85000-0x52fd3fff]
août 31 14:34:30 fedora kernel: PM: hibernation: Marking nosave pages: [mem 0x54965000-0x54965fff]
août 31 14:34:30 fedora kernel: PM: hibernation: Marking nosave pages: [mem 0x57f7f000-0x5affefff]
août 31 14:34:30 fedora kernel: PM: hibernation: Marking nosave pages: [mem 0x5b000000-0xffffffff]
août 31 14:34:30 fedora kernel: PM: hibernation: Basic memory bitmaps created
août 31 14:34:30 fedora kernel: PM: hibernation: Preallocating image memory
août 31 14:34:30 fedora kernel: PM: hibernation: Allocated 2617075 pages for snapshot
août 31 14:34:30 fedora kernel: PM: hibernation: Allocated 10468300 kbytes in 2.12 seconds (4937.87 MB/s)
août 31 14:34:30 fedora kernel: printk: Suspending console(s) (use no_console_suspend to debug)
août 31 14:34:30 fedora kernel: ttm_device_prepare_hibernation+0x69/0xc0 [ttm]
août 31 14:34:30 fedora kernel: amdgpu_device_suspend+0x159/0x260 [amdgpu]
août 31 14:34:30 fedora kernel: device_suspend+0x17e/0x4e0
août 31 14:34:30 fedora kernel: async_suspend+0x21/0x30
août 31 14:34:30 fedora systemd[1]: systemd-hibernate.service: Deactivated successfully.
août 31 14:34:30 fedora systemd[1]: Finished systemd-hibernate.service - System Hibernate.
août 31 14:34:30 fedora audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-hibernate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
août 31 14:34:30 fedora audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-hibernate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
août 31 14:34:30 fedora systemd[1]: systemd-hibernate.service: Consumed 5.116s CPU time over 11.045s wall clock time, 2.3M memory peak.
août 31 14:34:30 fedora systemd[1]: Reached target hibernate.target - System Hibernation.
août 31 14:34:30 fedora systemd-logind[1018]: Operation 'hibernate' finished.
août 31 14:34:30 fedora systemd[1]: Stopped target hibernate.target - System Hibernation.
août 31 14:34:30 fedora kernel: ACPI: PM: Preparing to enter system sleep state S4
août 31 14:34:30 fedora kernel: ACPI: PM: Saving platform NVS memory
août 31 14:34:30 fedora kernel: PM: hibernation: Normal pages needed: 2487678 + 1024, available pages: 4801244
août 31 14:34:30 fedora kernel: ACPI: PM: Restoring platform NVS memory
août 31 14:34:30 fedora kernel: ACPI: PM: Waking up from system sleep state S4
août 31 14:34:30 fedora kernel: amdgpu 0000:c1:00.0: SMU is resumed successfully!
août 31 14:34:30 fedora kernel: PM: hibernation: Basic memory bitmaps freed
août 31 14:34:30 fedora kernel: efivarfs: removing variable HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67
août 31 14:34:30 fedora kernel: PM: hibernation: hibernation exit
août 31 14:38:46 fedora systemd-logind[1018]: Suspending...
août 31 14:38:46 fedora ModemManager[1065]: <msg> [sleep-monitor-systemd] system is about to suspend
août 31 14:38:47 fedora systemd[1]: Starting systemd-suspend.service - System Suspend...
août 31 14:38:47 fedora systemd-sleep[156883]: Performing sleep operation 'suspend'...
août 31 14:38:47 fedora kernel: PM: suspend entry (s2idle)
août 31 14:38:49 fedora kernel: printk: Suspending console(s) (use no_console_suspend to debug)
août 31 14:38:49 fedora kernel: PM: suspend devices took 0.165 seconds
août 31 14:38:49 fedora kernel: amdgpu 0000:c1:00.0: SMU is resumed successfully!
août 31 14:38:49 fedora kernel: PM: resume devices took 0.199 seconds
août 31 14:38:49 fedora systemd-sleep[156883]: System returned from sleep operation 'suspend'.
août 31 14:38:49 fedora kernel: PM: suspend exit
août 31 14:38:49 fedora bluetoothd[946]: Controller resume with wake event 0x0
août 31 14:38:49 fedora systemd[1]: systemd-suspend.service: Deactivated successfully.
août 31 14:38:49 fedora systemd[1]: Finished systemd-suspend.service - System Suspend.
août 31 14:38:49 fedora audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
août 31 14:38:49 fedora audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
août 31 14:38:49 fedora systemd[1]: Reached target suspend.target - Suspend.
août 31 14:38:49 fedora systemd-logind[1018]: Operation 'suspend' finished.
août 31 14:38:49 fedora systemd[1]: Stopped target suspend.target - Suspend.
