Which Linux distro are you using?Slackware/64 Current
Which release version?
(If rolling release, last date updated?)Yesterday
Which kernel are you using?6.12.7
Which BIOS version are you using? IFR30.03.04
Which Framework Laptop 13 model are you using? (AMD Ryzen™ 7040 Series, Intel® Core™ Ultra Series 1, 13th Gen Intel® Core™ , 12th Gen Intel® Core™, 11th Gen Intel® Core™)13 Gen Intel I5-1340P Wifi works fine until a usb-A SD card reader is installed and then wifi drops. Unplugging card reader restores wifi
There are known interference issues between USB 3.0 and 2.4 GHz Wifi (not Framework specific; use your search engine to learn more). Perhaps that’s what you are seeing here? Here are some of the things that I would try:
Check if your problem occurs with 5.0 GHz wifi networks or only with 2.4 GHz.
Try using a different/longer cable for the SD card reader.
Move the Framework USB-A adapter around. If I remember correctly, the Wifi card is right next to the bottom-right expansion slot – if that’s where your USB-A adapter was, maybe move it to a different slot?
