Framework 13 with VMWare Workstation
Hi
Good afternoon,
I recently purchased a framework 13 (intel 13, 32 GB…)… I am very happy with the modularity and repairability…
I have installed Windows 11 Pro and all the necessary software for daily work, so far no problems.
But when I try to virtualize a machine with vmware workstation 17.5, I find that the performance is so low that it is not usable. Does this happen to anyone else? Additionally, it doesn’t let me enable Virtualize Intel VT-x/EPT or AMD-v/RVI even though it is activated in the Bios/EFI.
Thanks for all.
Really not a Windows pro, but did you check that Microsoft’s own virtualization technology is disabled, so AMD-v is not occupied and can be used by vmWare?
I find this
When I install VMWare Workstation, this install WHP…
If you disable the credential guard, fingerprint access stops working… or when I disable it I lose the acces with my fingerprint.
But I can run de VMWare machines with enable Virtualize Intel VT-x/EPT or AMD-v/RVI and it improve the performance.
Thanks a lot.
