Which Linux distro are you using? CachyOS KDE
Which release version? Rolling release. SKIP!
If rolling release, last date updated? Today 2025-12-23.
Which kernel are you using? 6.18.2-3
Which BIOS version are you using? The latest. Something-4.02
Which Framework Laptop 16 model are you using?
My Framework 16 v1:
Manjaro KDE
AMD Ryzen 7840HS
32GB Framework RAM kit
2TB NVMe Solidigm P41 Plus
My Framework 16 v2:
CachyOS KDE
AMD Ryzen AI HX 370
96GB Framework RAM kit
Hello,
I received my mainboard (batch 2) last week and finally got around to installing it and; I’m so neurotic and filled with joy and excitement; I have to share my experience.
The board came in a very large shipping box. You could probably easily fit 30 of those in there so I was pretty confident that there would be no shipping related damages.
The swap, with the mainboard guide, was easier than when I used to replace parts on my Samsung Note 2.
Finally, I put the new Framework 96GB memory kit in that baby, closed it up, grabbed a cold one, let out a sigh of mixed emotions, and pressed the power button.
Memory training was a breeze. It only took a few seconds. I then wiped the old install and decided to experience the BTRFS file system and CachyOS for the first time. New year, new me ![]()
And now the real fun stuff. How is it?
The OS experience is nothing like I’ve ever experienced before. The speed… the SPEED!!!
I’ve never seen UI animations that actually update so fast it feels like sci-fi. Especially for Linux. Granted there were still some visual oddities/glitches, but that could be because of the fresh minimal install with no extra setup. I guess I’ll need to experience a 360-500hz display panel before I ever get this feeling again, but I’ve still disabled animations as I can’t stand ‘em anyway ![]()
The smoothness of the mouse, windows, even in games (STS, Balatro, etc), feels like I also changed the display panel. It got barely warm during play and it’s so buttery smooth, I’m really getting the full 165hz / low-latency experience now. It’s giving my 5900X/6800XT/4K 144Hz desktop a run for its money. On v1 of my FW16 it also felt smoother, but only slightly.
Package installs feels like it’s sucking more energy than an AI data center with how fast things fly in the terminal. I barely lift my finger off the Enter button and it’s done.
I can reserve up to 48GB of memory in the BIOS for the iGPU ![]()
Overall, it doesn’t compare to anything else for me and my needs, and I no longer feel disappointment for not getting a Ryzen AI Max+ 395 option.
But surely not everything is as “perfect” as I say right? Right.
Boot/reboot times are atrocious. The blame is 3 way. Framework’s BIOS, I now use disk encryption on a low power/no cache NVMe (Solidigm P41 Plus), and CachyOS. I will eventually upgrade to a high performance 4TB NVMe drive and both Framework & CachyOS will continue to optimize things little by little, so no real complaints here.
The Kernel (and BIOS?) usb bug is still here. I’m still seeing the ucsi_acpi USBC000:00: unknown error 256.
It also royally crapped itself at some point last night while I was sleeping. Woke up to a barely responsive OS. Rebooted and everything from the BIOS to the OS was insanely sluggish. It also stopped charging like the v1 did once. Heck, even the BIOS menu lagged when navigating the menu. The fix was the magical “Disconnect Battery option in the BIOS + shutdown and hold the power button for 30 before connecting the original charger” trick. Everything is back to normal since.
Some final words.
I recommend the upgrade 100%. I’ll update here if anything pertinent comes up over the following weeks. I feel the same “I’ve never been happier with a laptop“ with the v2 as I did with the v1. I’m a very happy customer and glad I believed in the FW16’s mission even if it was pure torture to wait for a motherboard upgrade since day 1 as I had planned to use the first mainboard for my next home server upgrade months before the first FW16 was ever shipped.
Best of luck to everyone still waiting for their board. It feels like mine shipped a month later than expected. It threw a wrench in my schedule as I had planned a lot of things after the first confirmation e-mail. But with how good of an upgrade this is, it was worth the wait and emotional damage ![]()
And finally, a reminder to Framework. Where… is… my… RGB NUMPAD???
