which means there’s no deep standby. Here’s some relevant paragraph from arch wiki:
If your hardware does not advertise the deep sleep status, check first if your UEFI advertises some settings for it, generally under Power or Sleep state or similar wording, with options named Windows 10, Windows and Linux or S3/Modern standby support for S0ix, and Legacy, Linux, Linux S3 or S3 enabled for S3 sleep.
So the question is – is there “modern standby” support? Maybe there’s some additional configuration to do on the Linux side
part of the problem is I don’t know how much power consumptions I should expect / how to log the power draw each suspension (or if there’s any unexpected wakeup)
