Framework 16 & USB C
Hi all,
I have run into a bit of a doozy I cant seem to figure out. I am considering pairing a framework 16 with a samsung G8.
Would this combination be able to output 175hz at 3,440 x 1,440 using the top left USB C 4 module?
From my research I keep getting varying answers, if anyone has an idea or even some experience I would love to hear about it. Thanks!
The CPU inside the FW16 is the AMD 7840HS.
https://www.amd.com/en/products/processors/laptop/ryzen/7000-series/amd-ryzen-7-7840hs.html
So, what you want might work.
