It seems that the Framework is showcasing their laptops on their CES 2024 booth. The CES 2024 is 3 days event from 9th - 12th January. However, I was not able to find Framework’s booth information by searching on this page . I don’t know why.
https://www.techpowerup.com/317561/framework-demonstrates-laptop-16-customization-and-expansion-modules-at-ces-2024
Anyone visiting the CES 2024 event, did you see the Framwork’s booth? Or are their laptops showcased in another company’s booth such as AMD’s booth?
NotebookCheck wrote in german about the FW16 power supply :
Eigentlich wurden schon länger erste USB-Power-Delivery-Netzteile erwartet, die die vollen 240 Watt über ein Kabel schicken können. Stattdessen wird erst einmal die 180-Watt-Grenze geschlagen. – von einem Hersteller, der damit eigentlich nicht...
It seems there is Framework’s booth according to the following video (thanks for sharing!)
I found this tech outlet with some hands on with the framework booth at CES. Thought I’d share.
Framework 16 at CES
No. It seems that Framework doesn’t have their booth. Instead, it seems that Framework Laptop 16 is showcased in AMD’s booth.
https://www.reddit.com/r/framework/comments/193oqsm/framework_16_as_a_demo_unit_at_the_amd_booth_at/
A PCMag article about CES 2024 and Framework with their interview video!
The new 16-inch Framework laptop lets you swap the keyboard, the GPU, the ports, and the…well, everything. We go hands-on with it at CES 2024.
