Framework Desktop initial configuration
Which Linux distro are you using?fedora 43
Which release version?43
Which kernel are you using?6.17.12-300.fc43.x86_64
Which BIOS version are you using?The Framework Desktop is running BIOS version 03.04 (dated 11/19/2025)
Which Framework Desktop model are you using? (AMD Ryzen™ AI Max 300 Series) Max+ 395 - 128GB
I wrote a blog post about configuring the Framework Desktop for AI workloads. have a look!
https://biuiw.hashnode.dev/the-strix-halo-starter-pack-configuring-ryzen-ai-max-395-for-local-llms
