Framework Fan Art 🎨🖌️
i made a little logo animation! the framework logo is really fun to work with :^)
framework-logo
That is so cool! Can you upload one with a transparent background? Or possibly turn this into a loading icon? This would be nice to have as the loading cursor for my laptop.
Wow this is awesome!! @JacobFavreault idea is so good it would be so good for a loading cursor.
@sniss what software did you use to create that?
@JacobFavreault here are both versions of the animation in transparent!
framework_transparent
framework_transparent_2
@Rodrigo_Luzuriaga i used adobe after effects to animate and photoshop to export as gif :]
Something I have been speculative about but not 100% on is the asymmetry of the logo. It is symmetrical along the horizontal and vertical axes, but not along the “teeth” of the framework gear.
The circle is a perfect circle and the outline is the outer edge of the logo.
Edit: typos
Is it possible for you to provide the original file? Or to create a loop of this section where the teeth fold out then fold in, like in this cut?
Wouldn’t this look nice on the screen when booting the computer?
It definitely would, but that would require stalling for a few seconds to play an animation.
When can I get my OLED backplate to display stuff like this?
Pretty sure there’s an app for UEFI-boot systems that can change the windows logo to any image or gif
I only found this out recently, but it looks like the designer of the Framework logo is actually Cory Schmitz, who also designed the logo for Oculus, Polygon, and many notable video games. Wow!
this is so cool!!!~
These are amazing definitely going to be using some of these
It exists here. It has versions for Windows 11, 10, and 7. If you can see your OEM’s logo on boot, it most likely supports this. Check if your system has UEFI boot in the BIOS if you’re not sure.
Thank you for these! I ended up making a loop using them. It’s not perfect and is only 25fps, but it looks good enough, lol.
logo gif
Someone with more talent could probably refine it or make it better/higher quality.
Theres also a few linux graphic bootsplashes (like Plymouth). You should be able to use something like this gif as an image when booting. Once I have the unit in hand I will play around with it for sure, looks awesome!
heres what i think you’re lookin’ for. would work well for a loading animation :slight_smile:
framework-loop-2
That’s exactly what I was trying to make! Thank you!
I’m working on making something a little more lax than my previous ones, but I do not have the most creative mind.
Does anyone have any thoughts?
Maybe just a simple cogging over or the teeth smoothly pulsing in and out would be more relaxed.
