Framework Gen12 WSL2 problem
hmmm, now this is more a shot in the blue, what you can try:
Enable Windows Defender Credential Guard by using Group Policy
You can edit your local Group Policies by running gpedit.msc (first part of point 1, the Group Policy Management Console)
I would suggest doing the settings like they show them in the screenshot (point 5).
The important stuff is to enable Credential Guard Configuration.
Be aware: Do NOT enable Virtualization Based Protection of Code Integrity, leave it set to Not Configured otherwise this may run you in really big troubles (chances are low, but who knows).
Reboot afterwards.
You can simply revert this change by setting to radio button back to Not Configured and reboot.
Note 1: Enabling this could cause troubles with connecting to WiFi, if the WiFi you want to connect to only supports old authentication methods (which are known for being insecure for years now) you canā€™t connect to it.
Note 2: If your device is joined to a Domain, these settings could possibly be overwritten by GPOs set by your admins.
Iā€™ve encountered the exact same issue today. Docker refuses to work on both the WSL2 and the old virtualization engine. Manually installing wsl fails. Iā€™m getting the same errors as OP.
Using Gen12 Framework, @DanielK?
Please check if the Intel Trusted Execution Technology is disabled in BIOS.
Yes, gen 12, most expensive version. Everything related to virtualization (and almost anything else) is enabled in the BIOS.
Disabling Intel Trusted Execution Technology in BIOS has allowed Docker and Hyper-V to work!
Hypervisor is now reported as present, where previously it wasnā€™t.
@Heinz-Willi_Eichmeye, youā€™re a life saviour!
I wish A) Framework would not enable it in their default BIOS configuration and B) support be a bit more knowledgeable about this setting.
I can finally fully enjoy this amazing laptop! :grinning::tada:
You welcome!
Did you think through what youā€™re asking / wishing?
Iā€™m not sure what you are trying to say, but pretty sure that a few weeks of frustration could have been avoided if the setting was not enabled by default or if the support team wouldnā€™t keep telling me itā€™s a software issue. And by support, Iā€™m not referring to this thread.
Youā€™re asking for the OOTB security posture of the product to be lowered out of the box for everyone due to a 3rd party software execution requirement. The length of time of the frustration was a knowledge-base issue. (i.e. if you had known about it, on day x, then the frustration period is a derivative of x) Thereā€™s some degree of accountability here for the insufficient knowledge as an end-user. The relationship of docker is with you, the end-user, not between Docker and Framework. Older BIOS implementations had TXT disabled, Secured Boot disabled. However, the security landscape is changing (as always). and Secured Boot is enabled by default for many new laptop models. Itā€™s the direction of better security posture out of the box (enabled security feature by default, then disable security feature as needed per endpoint)
Secondly, if anything, the ā€˜supportā€™ should have come from Microsoft for Hyper-V and from Docker for docker. Itā€™s not up to laptop manufacturers to know / aware of 3rd party software requirements.
Regardless of your wishes, Iā€™m glad that youā€™ve found the solution.
