Framework handheld?
Do you think it is possible to build a steam deck sized handheld. If you can that would be amazing because you can upgrade it over time.
What would a Framework Steam deck do that the actual Steam Deck can’t? The Steam Deck is already quite repairable and open.
Make everything a module, hot-swappable APU without opening the case, move the USB-C port from the top to the right side of the device, etc.
I’m sorry, that’s literally impossible. Never once has there been a hot-swappable APU and there never will be.
sarcasm
@JRLarsen You’ll note this is text, try using a format suited to sarcasm like speech or using the classic “/s” to indicate sarcasm.
