Which kernel are you using? 6.16.7-200.fc42.x86_64
Which BIOS version are you using? 03.04
Which Framework Laptop 12 model are you using? (13th Gen Intel® Core™ i3-1315U × 8)
What’s going on?
Anytime I open the lid on my laptop, the display output is upside down - I assume it’s starting in tablet mode for some reason. To get it back right side up, I need to open the lid past 180 degrees and then bring it back to the desired laptop angle.
Is there anything I can change in the config to get it to start in laptop mode when opening the lid? If not I’ll just look into setting up a hotkey shortcut to flip the display.
Thanks, that seems to have fixed it! I compared the new config against the old one to see what changed, and it looks like this block got removed from the first configuration.
Side note: If I’m reading the file right, there’s one config per monitor setup, so this one was the “just my laptop” config, the other one in my file was for “this laptop + samsung monitor”, I bet it adds one for each new display combo.
All that said, if this happens again, I suspect that removing that transform block would fix it.
