Framework Laptop 13 Intel 12th Gen: Stuck on 400 MHz or not?
Have you ever noticed that your 12th Gen Intel is extremely sluggish because it’s stuck at 400 MHz (on all cores, for a prolonged time, even after cooling down)?
  • Yes.
  • No.
0 voters
If yes, let's collect some information to see if there's a pattern.
Which processor do have?
  • i5-1240P
  • i7-1260P
  • i7-1280P
0 voters
Under which BIOS version did/do you experience the 400 MHz bug?
  • 3.04 (factory version)
  • 3.05 (factory version)
  • 3.06 Beta
  • 3.08 Release
  • 3.09 Beta
  • 3.17 Release
  • 3.18 Beta
0 voters
What did/do you (usually) have to do to get your laptop “unstuck”?
  • Waiting a couple of minutes.
  • Waiting for more than 5 minutes.
  • Waiting for more than 10 minutes.
  • Waiting for more than 30 minutes.
  • Letting the CPU cool down.
  • Rebooting the computer.
  • Resetting the Embedded Controller (powering off & removing power for more than 2 min).
  • Resetting the mainboard.
  • Replacing the mainboard.
  • Other (see comment section).
0 voters
How were/are you using your laptop when the 400 Mhz bug happend/happens?
  • Opened (exhaust unobstructed).
  • Closed (e.g., with external monitor and keyboard).
  • Standalone (e.g., mainboard in Cooler Master case).
  • With a docking station.
  • On a flat surface with open air intakes (desk, table, etc).
  • On a soft surface with (partially) obstructed air intakes or exhaust (bed, couch, cushion, etc).
  • On the lap.
0 voters
The affected laptop was/is equipped with the following battery type(s):
  • None
  • 55 Wh
  • 61 Wh
0 voters
Were/are you on battery or connected to power when it happened/happens?
  • On battery.
  • Connected to power.
0 voters
If it happened/happens connected to power answering he following questions might give additional insights.
What kind of power supply was/is used during experiencing the 400 MHz bug?
  • None
  • < 30 W
  • 30 - 45 W
  • 45 - 65 W
  • 65 - 90 W
  • ≥ 90 W
0 voters
Which expansion card slot was/is used for the power supply?
  • 1 (rear left).
  • 2 (front left).
  • 3 (rear right).
  • 4 (front right).
0 voters
Under which operating system did/does your laptop get stuck at 400 MHz (sorry, no more than 20 options allowed)?
  • Windows 11 (officially supported)
  • Ubuntu 22.04 LTS (officially supported)
  • Ubuntu 24.04+ (officially supported)
  • Fedora 42 (officially supported)
  • Bazzite (officially supported)
  • Manjaro XFCE (community supported)
  • Linux Mint (community supported)
  • Arch Linux (community supported)
  • NixOS 24.11+ (community supported)
  • FreeBSD
  • Haiku
  • Windows 10
  • Debian Stable
  • Pop!_OS
  • openSUSE
  • Other Linux
  • OpenBSD
  • Other BSD
  • Another OS
  • None (e.g., UEFI, bootloader)
0 voters
Which power profile was/is active when the 400 MHz bug manifests?
  • Power Save
  • Balanced
  • Performance
  • Other
0 voters
What controls the power profile when the CPU is stuck at 400 MHz?
  • “Windows”
  • ppd - power profiles daemon (default on Ubuntu?)
  • tuned (default for Fedora)
  • thermald
  • auto-cpufreq
  • tlp
  • something else (see comments)
0 voters
Are you able to reproduce the 400 MHz bug intentionally (e.g., by starting a certain game or running a certain program)?
  • No.
  • Yes.
0 voters
If you’re able to trigger this bug intentionally, please, mention in the comments how you achieve this.
If no, let's see what might help to prevent the 400 MHz bug from happening.
What’s the processor on your mainboard?
  • i5-1240P
  • i7-1260P
  • i7-1280P
0 voters
Which BIOS version(s) have you used for more than a week?
  • 3.06 Beta
  • 3.08 Release
  • 3.09 Beta
  • 3.17 Release
  • 3.18 Beta
0 voters
How are you usually use your laptop?
  • On the lap.
0 voters
Your laptop is equipped with the following battery type:
  • None
  • 55 Wh
  • 61 Wh
0 voters
Are you usually using your laptop on battery or connected to power?
  • On battery.
0 voters
What kind of power supply is usually used?
  • < 30 W
  • 30 - 45 W
  • 45 - 65 W
  • 65 - 90 W
  • ≥ 90 W
0 voters
Which expansion card slot(s) is/are used for the power supply?
  • 1 (rear left).
  • 2 (front left).
  • 3 (rear right).
  • 4 (front right).
0 voters
Which operating system(s) do you usually use (sorry, no more than 20 options allowed)?
  • FreeBSD
  • Haiku
  • Windows 10
  • Debian Stable
  • Pop!_OS
  • openSUSE
  • Gentoo
  • Other Linux
  • OpenBSD
  • Other BSD
  • Another OS
0 voters
Active power profile(s)?
  • Power Save
  • Balanced
  • Performance
  • Other
0 voters
What controls the power profile(s)?
  • “Windows”
  • thermald
  • auto-cpufreq
  • tlp
0 voters
Funny, this just happened to my laptop an hour ago.
Found a thread here that helped me out.
The throttle occurred on Fedora 42 and persisted through multiple reboots. I booted into W11, and it was still happening.
It stopped after I had replaced the thermal paste, though the real fix was likely having powered down for 2 minutes while disconnected from power as the poll suggests.
Hello @next_to_utter_chaos !
I am not affected, but I have just taken part in the survey.
It may be useful to query some additional information, e.g:
Bios settings (optimised standard loaded, load limit, secure boot active, …)
Board identifier (if I remember correctly from a driver package thread, the board is available with different identifiers)
Delivery Batch
Other hardware (memory size, type and parameters; SSD type, size and firmware; plug-in modules used;…)
You don’t happen to have a complete list for the 12th Gen mainboards?
I think I could try to get a partial one from the install scripts in one of the older (pre-merge with 13th Gen) driver or bios packages but I’m not sure if that’s better than just let everyone add a comment with any further information they might want to add.
I can produce this fairly easily.
It occurs about 10 minutes into a zoom meeting.
My laptop typically runs quite warm, as I’m running VMs / doing dev work.
Software builds / generally keeping things going hot is fine.
It’s just this zoom meeting!
Right I’ve got it back to running normally.
I think it’s related to the battery level.
I was using the USB-C charger to charge something else, and using battery power.
Then switched back to plugging it in.
The frameworks power was down to within the 20% range, and it started acting normally in the 70-80% range.
I always have to reboot and do a battery disconnect to get it to stop throttling. It’ll go on forever if I don’t do that, and even survive reboots. It’s happened consistently for the 2-3 years I’ve had the laptop, but more often in hot weather.
Great post. Would it be possible to update the poll in regards to BIOS versions since 3.18 and 3.19 stable releases are out?
I’m assuming there are some people who are still experiencing this issue depsite being on the latest BIOS (and running the Retimers if on Windows).
It does appear the issue impacts those on i7 CPUs more than i5 CPUs.
I am still having this issue despite updating to the latest BIOS, though I also have an issue with that (see my post here, which also includes my laptop specs)
Aaaaaaaaaand no, doesn’t work, the EC flipcs BD_PROCHOT back on immediately, an issue that’s logged on that Github script (Ctrl + F “Write succeeds but the value reads back unchanged”)
Also for what it’s worth I have the latest BIOS, 3.20 (command for checking it is: sudo dmidecode -t bios)
I got Brave AI to get me a solution that just keeps disabling BD_PROCHOT really fast, but that doesn’t work either, probably because the EC resets itself really fast (every millisecond or so)
EDIT: I somehow replied to the wrong post, I was trying to reply to this one:
Patch it out of the ec then (if it actually is the ec and not something else)
How could I do that?
It’s a bunch of work and I have not actual seen anyone mess with the intel ec but it is open source.
Probably not a very viable option though.
If the EC is open source just search “prochot” as a key word and delete (or just remove it from the loop) them. Deleting BD PROCHOT isn’t going to make the CPU overheat as thermal throttling uses another logic
Prochot may have been used for early primitive thermal throttling initially but currently it is mostly used as a “Everyone slow down before we crash” emergency break for external components (charge controller, vrms, ec logic, stuff like that). They usually still have safety shutdown after that but brief slowdown is usually preferable over crash.
Except giving the widespread of 400MHz without any visible mechanical or electrical damage, the “emergency break” is very likely to be a false positive and it doesn’t even self-reset. Even if it’s not false positive, I don’t think a bread cutter gonna need that XD
That wasn’t my point, the point is it is a courtesy warning before the various things go into self protection. For example vrms overheat they prochot first to maybe slow down instead of crash but if that doesn’t help they just turn off, no more power downstream → crash.
The prochots done by the ec (at least on the amd side, haven’t bothered with the intel code much as I don’t have one) were to try to avoid overloading pd supplies during state transitions but that is less of an issue as long as a battery is present. Same with the way too trigger-happy input current prochot that isn’t even necessary when a battery is present but probably helps a lot to survive without one.
I had actual overheating issues. Fixed it by replacing the fan assembly.
