Framework Screwdriver + Calipers Storage Box = ❤️
Many years ago, I bought calipers that came with a generic storage box.
For all those years, I wondered what was supposed to fit in the second compartment.
The Framework Screwdriver fits perfectly.
Thank you! :smiley:
Where can I buy those calipers? Specifically want it for also the case. :slight_smile:
perfection
That depends on where you live. I bought mine on Amazon Germany.
The calipers and the box are generic Chinese brands. If you find calipers with colored rubber buttons, an arrow on top of the battery compartment*, and a storage box with a zigzag pattern, it’s probably the same. :slightly_smiling_face:
*Note: Some models have the battery compartment lid screwed on. Look for calipers where the lid slides to the side.
For example, this one looks identical: Amazon Germany
Found a different one sold in Amazon US with a different name. I didn’t realize it was generic, lol. The case looks identical!
https://www.amazon.com/Electronic-Micrometer-Measurement-STEAD-FAST/dp/B09985QCL9
