Which Linux distro are you using? Void
Which release version? today
Which kernel are you using? 6.6
Which BIOS version are you using? 3.19 I think
Which Framework Laptop 13 model are you using? 11th Gen Intel® Core™
I’ve got a 140W charger that provides power nicely.
Unfortunately it seems that my framework laptop will, when plugged in for an extended period of time, occasionally re-negotiate with the charger (or the charger re-negotates with the laptop). Then it fails to do so, the white light on the side turns off, and the laptop won’t charge until I unplug and replug the cable.
I suspect this is something with the charger offering 28v per the 140W USB PD EPR spec, and my 11th gen 13" not recognizing it.
