Fedora 41 KDE
Which kernel are you using?
6.12.7-200.fc41.x86_64 (64-bit)
3.05
Which Framework Laptop 13 model are you using? (AMD Ryzen™ 7040 Series, Intel® Core™ Ultra Series 1, 13th Gen Intel® Core™ , 12th Gen Intel® Core™, 11th Gen Intel® Core™)
AMD Ryzen 5 7640U
Earlier today I was using Firefox on my FW 13, I had began noticing my CPU temp was creeping up even thought I was just looking at emails. Then the system experienced extreme slow down. My mouse cursor would only move at what felt like 1fps. I could still interact with the computer and it seemed like opening tabs and opening a terminal ran at the correct speed. It was almost as if just everything was being rendered slowly.
I checked CPU frequencies and they looked normal. I had experienced this before on Fedora 40 months ago, and while it happened multiple times a week back then, I had not experienced this issue in a couple of months.
I checked top and noticed there was a kworker process at almost 100%. This seemed similar to [TRACKING] Kworker stuck at near 100% CPU usage with Ubuntu 22.04
I ran perf as that OP did and saw the following.
I also ran dmesg and saw a couple of amdgpu errors
Rebooting fixes the issue.
