FW13 Ryzen AI 9 HX 370 Bluetooth laggy when system under medium load
hi,
i’ve a FW13 running openSUSE Tumbleweed with an AI 9 HX 370 and the MEDIATEK MT7925 Wi-Fi 7 the driver being used is: mt7925e.
I’ve connected my keychron K3 Pro wirelessly via bluetooth. Everything works fine until the Framework gets some work to do. Like copying files to a USB Drive or compiling some stuff.
Then my bluetooth keyboard gets “laggy” the chars that i type take longer until they appear on the screen (1s - 3s) sometimes they just repeat until the next key is received. this looks sth like this:
hellllllllllllllllllllllllllllllllllllllllllllo although i wrote hello
here are some infos about my system:
CPU: 12-core AMD Ryzen AI 9 HX 370 w/ Radeon 890M (-MT MCP-)
Network:
  Device-1: MEDIATEK MT7925 Wi-Fi 7 160MHz driver: mt7925e
Bluetooth:
  Device-1: MediaTek Wireless_Device driver: btusb type: USB
  Report: btmgmt ID: hci0 state: up bt-v: 5.4
Kernel: 6.16.1-1-default x86_64
any help or suggestions are welcome :slight_smile:
greetings
Hello! Please send our support team a message. They’ll be happy to help pinpoint the issue for you.
