You are right, thats it. This is fine. I couldnt find it in my German Framework Store.
Daaaammn. Im going to be on Deployment shortly. So i don’t have enough Time to order one and tinker more
but maybe someone else hops on my tinker Train.
I am thinking about making an extra Thread with the Build Log Recap, to give it more attention and to get the Company more aware of how much Performance is left on the Road currently.
Maybe i just wait of maybe a V2 Heatsink.
As they state on the Partscatalog its able to dissipate a continous 45w.
Well its able to dissipate a stable 50w
After seeing everyones performance issues curiosity got the better of me and I decided to run some benchmarks and found that I’m also having the same issues. Fingers crossed the support process goes smoothly. seems like their qc issues creeped into batch 21 too
Good luck with this!
I’m currently on day 21, waiting for the label
Well my RMA took 10 Days from first Contact to Mainboard in my Hands. Sounds sad, that they took that long for you.
Looks like I’m having a similar issue with my Ryzen 9 7940HS. Will start on more testing this week & start the RMA process.
As an earlier batch 5, now I worry…
I don’t benchmark anymore. I just use, lol. But now I’m curious as to what Cinebench R23 score I get now that I have some reference points from your posts.
I was surprised to see bumps on the plate. I would have thought it would be flat for best mating and thermal conductivity. Strangely, the photos on their marketplace for the heatsink plate shows no bumps at all.
Click and zoom into the plate. Makes me wonder if you order the part as it is, if it will not have any bumps. Still questionable if it’ll be smooth and flat with better contact.
It would be great if the Replacement is like the one in the Picture. Maybe it’s the “older” Version the Review Units and older batches had. We assumed, that the “bumps” are the etched Area to help with the Surface Tension of the LM the FW Team mentioned in their Liquid Metal Deep Dive.
I will order one to crossreference and have something on the shelf if i destroy my current one. But im up for deployment next week. So i will have to wait till im home again to not destroy my Laptop beforehand without Time to fix it
I would love to see how your Batch 5 performs in CB23.
So just did a 10 run Cinebench R23 & barely getting 14000 to 14500 score & temps below:
Gettting uneven spread across the cores, swing is over 20c on Maximum temps from highest core to lowest!
I can’t help but wonder if we should ping someone from Framework to look into this.
As an aside, my replacement Mainboard arrived today and it scored an average of ~15600 in CB R23 with an 8°C core-to-core delta. While this exceeds the minimum score listed by NotebookCheck, something just doesn’t feel right. I’ll be keeping a close eye on this.
Welcome to the club…
I have very similar case (but I have Core 3 on 100C while Core 0 on 82-86C max on multicore stress test). Results are here: High CPU temperatures at low utilization - #27 by Dmitry_Elsakov
I did ping Destroya in the User Review Thread. There i posted about the Issue and my Modification.
Your Replacement looks fine enough.
Are you sure that you want to test it?
I ended up with the RMA because of this test.
Sometimes it’s best to stay ignorant.
What are your thermals looking like after the mod? And what has happened to your core-to-core temperature differences? Did they stay about the same or did they even themselves out?
Just some info for everyone else. FW support reached out with the request to run R23 and provide thermals.
I did so - and, the results were pretty much as everyone else said:
As seen, a temp delta of about 15 degrees, a really low score, and Core 4 was at 100c pretty much the whole time.
Biggest issue is only getting about 36 watts of package power.
They evened out more and more, and the coldest Core switched to another Core. But my highest Delta is still 9C.
@knipp30
Ouch, yep thats far off. Mine is pulling around 54w decreasing to 50w over 2 or 3 Loops and my Core Frequency is between 4.16-4.4 during cinebench R23.
Yeah, I was only getting 35.3W on mine. My RMA has been approved & getting sent an new motherboard.
Hopefully that will resolve it.
Well, I just checked and it appears to be similar to all you guys.
Biggest dT is 15 degrees Celsius. While the benchmark is running, all cores are at 4 GHz.
I’ve submitted a support request, We’ll see what happens
Pretty much same as mine - about 36W, but for 7940HS.
Waiting for replacement motherboard…
And result… less than 10k points for multicore…
BTW - I have replaced motherboard and now results are pretty great - details here, in other thread.
