[FW16] Question regarding thermal pads for ssd/ RAM
I remember , there was a a thermal pad attached to SSD in one of the reviews, is there a recommended size of thermal pads required for RAM / SSD when using with framework 16? I have purchase a sk hynix p41 for usage with the laptop.
Any recommendations from users and framework team? Is using thermal pads on SSD and RAM being ultra paranoid?
have you tried it?
I wouldn’t bother worrying about it initially.
https://www.reddit.com/r/framework/comments/1ad0ol6/is_the_thermal_padstripe_for_the_ssd_delivered/
Basically install the hardware, power it on, monitor temps and worry if you start to see throttling.
