Hey all,
I understand that the USB-C connection on the back of the 7700s GPU module is primarily used for Alt mode connection for a display. Am I right to assume that it should be able to connect more than one monitor using a dock? I tried two different docks and can’t get both monitors to pop up.
Windows 11 Pro
7700S GPU Module
AMD 7940 processor
Built in display
2x Asus 1080p 165hz monitors
- Razer thunderbolt 4 dock… Both Asus monitors connected using DP to USB-C DP cables confirmed to be working using this dock on another computer.
Only one monitor is seen by the computer. Restarting will randomly choose one of the monitors to use. Never pops up both monitors
- G5 HP dock essential… Monitors connected using DP to DP cables, neither monitor works.
With this said If I plug the USB-C from the docs into expansion slot 4 both monitors work as expected using the APU.
I’d really like to connect these monitors using the 7700S.
Has anyone had success connecting two monitors using a dock along with the built in monitor as a third? Thanks!
