Graphical issues
The first thing my computer did when I turned it on is flash weird glitches on my screen, they went away after a few seconds so I wasn’t too concerned and they have been happening since, usually caused by the screen moving or the laptop being bumped, recently the flickering glitches have not gone away unless I reboot the computer?
It looks like a faulty display to me. FW support should be able to help.
While it might be a driver bug, the patterns I see, like slices of the display with repeated content is more commonly due to a display panel fault.
@James3 might be right, but I would check the connector first to make sure it’s seated completely and then cable to make sure it’s not pinched or torn. If that’s all good then likely a bad panel.
