Edit: The below error is because audit2allow will only work if it has already denied an operation.
audit2allow - generate SELinux policy allow/dontaudit rules from logs of denied operations
In this case, the hibernate failure was due to secure boot still being enabled, and so it was not a SELinux policy denial.
I’m encountering the exact same error as @Panos_Sapou. I’m on a Framework 13 with a fresh Fedora 40 install.
Starting from step 11 (after reboot):
miles@fedora:~$ sudo systemctl hibernate
[sudo] password for miles:
Call to Hibernate failed: Sleep verb 'hibernate' is not configured or configuration is not supported by kernel
miles@fedora:~$ sudo audit2allow -b
miles@fedora:~$ cd /tmp
miles@fedora:/tmp$ sudo audit2allow -b -M systemd_hibernate
compilation failed:
systemd_hibernate.te:6:ERROR 'syntax error' at token '' on line 6:
/usr/bin/checkmodule: error(s) encountered while parsing configuration
miles@fedora:/tmp$ cat systemd_hibernate.te
module systemd_hibernate 1.0;
miles@fedora:/tmp$
I achieved the whole tutorial successfully after many attempts, but I got stuck in getting it working. Whenever I call sudo systemctl hibernate, I get a black screen then I spawn in the login screen the following second. What could be happening?
On my side, resuming from hibernation doesn´t work anymore with 6.11.4-201.
It remains stucked on framework splash screen before grub kernel selection menu.
Helpful guide for the newer versions of Fedora. I’ve installed Fedora 40 on ext4 rather than btrfs. I’m trying to get this guide to work with the only change being the use of the following to get the offset value:
With systemd v255 and superior, there is normally no need to set --resume and --resume_offset anymore.
I don´t use this args and hibernate is working.
I use btrfs, but I don´t think the filesystem is relevant here.
I also have exactly the same problem. Is there any way to solve it? By the way, when I modified the SELinux policy and restarted the sudo audit2allow -b output did not change.
I followed the rest of the guide in case of troubleshooting. I declared hibernation, reconnected immediately afterwards and extracted the logs from the previous minute.
Here are the most interesting lines in my opinion:
janv. 04 12:41:59 fedora systemd-logind[1674]: Sleep state 'disk' is supported by kernel.
janv. 04 12:41:59 fedora systemd-logind[1674]: Sleep mode 'platform' is supported by kernel (/sys/power/disk).
janv. 04 12:41:59 fedora systemd-logind[1674]: Swap partition '/dev/zram0' is a zram device, ignoring.
janv. 04 12:41:59 fedora systemd-logind[1674]: Detected enough swap for hibernation: Active(anon)=2155808 kB, size=26214396 kB, used=0 kB, threshold=98%.
janv. 04 12:41:59 fedora systemd-logind[1674]: Trying to acquire polkit authentication for 'org.freedesktop.login1.hibernate'.
janv. 04 12:42:00 fedora systemd-logind[1674]: Polkit authorization for action 'org.freedesktop.login1.hibernate' succeeded.
janv. 04 12:42:00 fedora systemd-logind[1674]: Sleep state 'disk' is supported by kernel.
janv. 04 12:42:00 fedora systemd-logind[1674]: Sleep mode 'platform' is supported by kernel (/sys/power/disk).
janv. 04 12:42:00 fedora systemd-logind[1674]: Swap partition '/dev/zram0' is a zram device, ignoring.
janv. 04 12:42:00 fedora systemd-logind[1674]: Detected enough swap for hibernation: Active(anon)=2156812 kB, size=26214396 kB, used=0 kB, threshold=98%.
janv. 04 12:42:00 fedora systemd-logind[1674]: Trying to acquire polkit authentication for 'org.freedesktop.login1.hibernate'.
janv. 04 12:42:00 fedora systemd-logind[1674]: Found matching previous polkit authentication for 'org.freedesktop.login1.hibernate'.
janv. 04 12:42:00 fedora systemd-logind[1674]: The system will hibernate now!
janv. 04 12:42:00 fedora systemd-logind[1674]: Sent message type=method_call sender=n/a destination=org.freedesktop.systemd1 path=/org/freedesktop/systemd1/unit/hibernate_2etarget inte>
janv. 04 12:42:01 fedora systemd-logind[1674]: Operation 'hibernate' finished.
janv. 04 12:42:01 fedora systemd-logind[1674]: Got message type=signal sender=:1.2 destination=n/a path=/org/freedesktop/systemd1/unit/swap_2etarget interface=org.freedesktop.DBus.Prop>
Hi all,
I managed to enable hibernation on my fw13 amd running fedora 41 with enabled encryption during install. I used the steps described here:
the process is actually pretty simple.
No need for repartitioning or kernel modules.
Also I didn’t need any workaround for the wifi to resume after waking up. That part just works for me.
Got this working on my laptop 12 with fedora 43 WITH a luks encrypted btrfs root WITHOUT secure boot. There was one hickup:
Everything went just fine, exactly as described, until step 15:
$ sudo systemctl hibernate Call to Hibernate failed: Specified resume device is missing or is
not an active swap device
And sudo audit2allow -b didn’t show anything.
After some troubleshooting it turns out it went wrong way back at step 4. sudo findmnt -no UUID -T /var/swap/swapfile returned the UUID of the btrfs root, but the kernel needs the mapped version to the unencrypted version of the fs. (I think, I don’t 100% understand this tbh)
What worked for me was to use sudo findmnt -no SOURCE -T /var/swap/swapfile, replacing UUID with SOUCE. It gave me the output /dev/mapper/luks-06fcd5cf-f390-4d5a-acd7-15d83fbe1b5a[/root].
In step 6, replace "resume=UUID=0123-uuid-0123..." with "resume=/dev/mapper/luks-0123-uuid-0123..." (without the [/root] part), with of course the new uuid of the mapped fs, not the old uuid of the encrypted btrfs. The offset remains unchanged if I remember correctly.
With that one tweak the rest of the guide went exactly as described, except that step 16 (wifi fix) was not needed. (I just skipped it out of curiosity and didn’t have issues.)
Thanks a lot for this well-written and easy to follow guide.
I hope my findings are useful to someone.
