[GUIDE] Framework DSP — better Linux audio
I will do so soon. I still have to transfer my GPG keys over to the laptop so I can sign the commit. It’ll be configured via home-manager, so if you don’t use that it might be of limited use.
It’s here:
Please note that I have some extra machinery in flake.nix that would allow me to replicate this config to other computers and have it recognize when it’s on the FW16 and only turn it on then.
If you wanted to use the ones that use the data files you might want to use Git LFS.
Sweet thanks! This’ll save me some time getting mine setup
Edit: Wow, huge improvement
I’m not super familiar with EasyEffects. Wondering how I should:
A. Prevent this profile from applying to any audio outputs besides the built-in speakers
B. Start EasyEffects upon user login to run in the background, but be able to bring it to foreground to interact with it.
This note from EasyEffects FAQ might be needed:
Question 5 - How to disable EasyEffects config when using headphones?
Answer: One solution for this is to create a preset where all plugins are disabled and create a preset autoloading profile that loads this preset when the headphone is plugged.
Also, it seems like easyeffects --gapplication-service is supposed to run in the background. I’m not sure how that works out when you open the program, if it opens and just points to the running background service.
This is turning into a small info dump as I figure things out. I lean towards using drop-in .xinitrc files to start things upon login versus ~/.config/autostart/*.desktop files. (xinit doesn’t support this for users; I just added the functionality to my .xinitrc). I think I’ll just put easyeffects --gapplication-service & in one and see how it works out.
I don’t understand where this “replace %CFG% with your config file” is supposed to be. I can’t find a reference to this “file” anywhere. I am so confused.
~/.config/easyeffects
Just do sed -i s:%CFG%:$(realpath ~/.config/easyeffects): <filename> assuming your home directory doesn’t contain :
Just want to share if someone use flatpak version of EasyEffects
Do the command then just copy irs and output folders from
to
~/.var/app/com.github.wwmm.easyeffects/config/easyeffects
:wink:
Has anybody else experienced video playback issues with EasyEffects running?
Is it possible for Framework to somehow integrate these improved audio DSP algorithms into the chip, so people don’t have to run EasyEffects etc?
It is — for instance, Ploopy Headphones do DSP processing on their RP2040 chip. I am almost sure it is possible to fit it into much smaller form factor and put into the chassis.
However, it will require a tighter integration than just plugging it into speaker port — for configuration and for power management. So I am not sure how to make a simple and portable mod easily.
(And there’s also an issue with Framework not providing schematics :D)
That’s a game changer - I wasn’t aware of this solution.
Thank you!
It may be possible already with the Realtek chip on the board! Though unfortunately I haven’t been able to find a leaked datasheet for it. The Framework team might be able to look into though.
Has been covered here a bit: Improving perceived sound quality on the FW13 - #6 by JabbAlecto
Would be nice if the ALC295 datasheet was available and someone could see what could be done via DSP.
wow, this is crazy. Sounds like MacBook speakers now :smiley:
Great job!
I’ve had occasional crackling in my audio when using this, what’s the best way to resolve that?
Crackling could be a kernel scheduling issue.
I’ve had a similar symptom that was resolved when I tried out a Linux-RT (realtime) kernel.
Maybe tweaking the audio buffer size could also help, but I’m not sure.
An interesting note from Framework was the fact that the keyboard was upgraded to use plastic on the wider keyboards to reduce buzzing.
@cab, for whatever reason your profile is now very muddled on my laptop. Not sure when it happened, but it seems to be recent, within a month or so. I’ll have to play around with it some to figure out what changed (probably something I did :).
Do you work close to metal dust or shavings? Sometimes they stick onto speakers, and reduce sound clarity a lot.
No shavings that I’ve seen. I’ll have to play with the profile a bit more, maybe narrow down what’s causing it. It’s almost like I’m missing something in the plugin chain.
This sounds great. However, is anyone else experiencing this issue because of the effects Sporadic audio crackling · Issue #1567 · wwmm/easyeffects · GitHub ?
My fault. It was so obvious once I really took a look. I had the monitor set to listen on the bass enhancer. It wasn’t obvious until I lost my mind and just started fiddling with all the plugins and buttons…Sigh.
