HDMI/DP Combo Port
Randomly found this video on the internet. Wondering if that could be implemented upon expansion card
That guy is so excited, lol! Pretty cool.
Given that the connector is not even advertised with any kind of speed for HDMI or DP, I suspect it might have problems reaching higher speeds.
Also, it relies directly on DP++. So you’d need to fit electronics into the expansion card to reconstruct a DP port with DP++ (USB-C cannot carry DP++).
And DP++ has been pretty much limited to HDMI 1.4 speeds in practice. So probably another reason for why this has not been widely used.
https://www.rego.com.tw/product_detail.php?prdt_id=76
Also, I cannot believe that this would be as secure as a normal HDMI port. I’d assume it breaks easier than classic ports as it will hold the connector less in place with the outer casing than a normal port.
