Should be, here’s someone that did it for the DP card firmware update.
That’s encouraging
Thanks!
Is TLP’s USB autosuspend not effective here?
Autosuspend doesn’t enter into it I think - there is no “device” to suspend. To signal the device you need to have 5v on the port and thats what causes the power draw even with “nothing” in there.
I can confirm that I did the mod and flashed it from inside a Windows virtual machine.
Thank you, too!
Now I am very sure that if it goes wrong it will be my fault.
