Success running helloSystem 0.7.0 on a Framework Mainboard with the 11th Gen Intel® Core™ i5.
helloSystem is a desktop system for creators with a focus on simplicity, elegance, and usability. Its design follows the “Less, but better” philosophy. It is intended as a system for “mere mortals”, welcoming to switchers from the Mac. FreeBSD is used as the core operating system.
Caveats
- Currently the GPU does not get recognized yet. As a workaround, one needs to start with
set initgfx.detect.disable=1as described athttps://hellosystem.github.io/docs/developer/graphics.html#disabling-the-automatic-graphics-driver-setup. - Compatible Intel WLAN drivers are not in helloSystem 0.7.0 yet, but are being worked on in the FreeBSD project.
- Only the Framework Mainboard but not other Laptop components (such as battery, touchpad, fingerprint sensor, etc.) was available for testing.
