My laptop keeps beeping a set of double beeps up then down every thirty seconds or so. Listen to the linked video. I have no idea what is causing this or how to make it stop. Framework 13 with 11th gen intel. Thank you. in advance.
That seem to be notification sounds… Identify which even causes the notification sound to be issued?
Those sounds indicate devices being connected and disconnected. Launch Device Management and try to see what is disconnecting and reconnecting. That may lead you closer to a culprit.
