Help in choosing processor/integrated GPU laptop 13
Hello,
I am planning in buying the 13’ model, mostly for working at home etc. but I would like to game a little bit, and in particular I would like to be able to play Diablo IV and it has high requirements. As I am quite lost regarding the CPU/GPUs, I would like to get some advice for the choosing of the processor (if there is any of the models capable enough)
thanks in advance,
best regards
So the best processor would be ryzen 7 7840u as it’s iGPU performance is just under a desktop GTX 1060 so you should be able to play it at 1080p 60 fps with medium settings. However, you’ll have to wait at least until Q4 to be able to get it. Another option is you could buy an eGPU to use with the laptop. In that case, the i5 1340p is more than enough and you can get it in a week or 2.
