Have used Ubuntu/W11, and idle power usage was much lower. Fans also running all the time, and underside is too hot to use comfortably on lap. This is strange because, iirc, the fans were almost never on with Ubuntu/W11.
Install process was download iso from Fedora website and install normally. I am on BIOS 3.05, have PPD installed, and my power profile in desktop GUI is power saver. Above screenshot is idle with single terminal window open.
I am not sure what I have done here? I remember this kind of performance when I initially installed Ubuntu, before I installed (I think) firmware? But Fedora is supposed to run fine out of box?
Any help appreciated. I am not sure what settings I need to check to debug further.
EDIT: using ~16W with a single YouTube window.
