Hot Keyboard - TheLPeink 10€ fix
Hi everyone!
In 2024, I sold my laptop and desktop to buy a Framework 16. Under the hood lie a 7840HS, 32GB of ram, 4TB of SN850X NVMe and the 7700S.
While using it for gaming, especially in High Performance mode (even more so with the 240W charger that unleashes the full sustained TDP of the machine), the keyboard gets hot.
Not unbearable, but surely noticable and annoying.
So… I armed myself with a Mileseey TR10 thermal camera and went testing!
Testing setup:
The warmup period was, in both cases, 30m of non-stop Furmark Stress testing:
Furmark CPU burner - 8 threads (enough to pull >30W sustained from the CPU)
Furmark 1080p stresstest - enough to pull 80W sustained from the GPU.
Cooling setup:
KLIM Cyclone cooling pad on full blast to cool the underside of the machine
7700S fans at 100% using Framework Control Center.
The pictures i’m uploading here represent the maximum temperature reached after the initial 30m test.
The timeline is:
CONTROL RUN - NO MODS APPLIED
  1. machine off
  2. 30m Furmark warmup with stock midplate
  3. 2m of pictures taken every 10 seconds
  4. equilibrium temp (average) reached during step 3.: 50.5° Celsius
  5. machine off, cooldown to room temperature
MOD TEST RUN - AEROGEL&THERMAL PAD APPLICATION AND TESTING
  1. disassembly of midplate
  2. applying thermal resistor (0.5mm aerogel sheet bought on Aliexpress) in “hot” areas (left side of the laptop:
  • two pieces (slices?) of Aerogel in the upper left corner
  • two pieces of A.g. on the center heatpipes just blow the WLAN card
  • 3 pieces of A.g. in the middle area between the heatpipes and the SSD
  • 1 piece of thermal pad (conductive, random pad I had lying around, ~0.25mm) just above port 2 of the laptop (you can see the small blue residue from a prior test fit); this was applied to help the midplate transfer heat to the chassis below. In the following picture you see the corresponding side of the midplate (which is upside down), with the thermal pad applied.
    3.30m Furmark warmup with modded midplate
  • 2m of thermal pictures taken every 10 seconds (same as above)
  • equilibrium temp (average) reached during step 3.: 47.3° Celsius
  • Notes: I took the average reading: In both cases, there was a ~±1°C oscillation.
  • The thermal camera is calibrated (I live at sea level, I used some boiling water and it showed 99,8°C).
  • The images of the laptop are upside down (spacebar/touchpad UP: the camera is aiming at the LCNTRL button). This is due to the way I fixed the camera on my shelf to take the pictures from the same position every 10 seconds.
  • The temperature reading is the one in red, in the center of the screen. It’s the max reading of the whole 192x192 image.
    Conclusion:
    Purely based on hand feeling (I called my unsuspecting girlfriend to test the keyboard to avoid placebo), she felt the second run noticably colder, and so do I. Overall the aerogel sheet (A4 size) was 10€, I had fun playing around with it and my keyboard is less scorching, so I’m calling this one a win.
    Feel free to ask for clarification, I enjoy discussion about thinkering! :slight_smile:
    See you next time!
This sounds pretty cool!
For me the more annoying thing is how hot the bottom side of the laptop gets when I have it on my lap while still plugged into power. Not talking about any heavy CPU or GPU scenarios, just having a basic text editor and a couple of browser tabs open. It gets downright uncomfortable.
I wonder if the aerogel could be used to insulate the bottom cover better… And if it can, would it be detrimental to laptop’s health in any way.
I had good success with setting the minimal fan speed to 20%, to cool it when idle
Try using Framework Laptop 16 Windows Fan Control Tool (NEW GUI)! and crank up the fan. The default fan curves for laptops nowadays are tuned for silence and keep the chassis at a “hot enough to be uncomfortable but not hot enough to burn you” stage
I agree with keeping the fan at 20% (inaudible) even when under very light loads. The bottom stays cool.
Oh…. Interesting…. I need to find something.. don’t know much about aerogel..
But sounds like it works for you
I just tried something similar on my 13, thermal camera image looks pretty similar and temperature is only like a degree or two lower but it indeed subjectively feels cooler and more even.
To be fair not sure what I got is actually aerogel but it certainly felt weirder to cut than anything else I have cut before.
This is so true lmao. Reminds me of the dragon clouds in Asian restaurants.
