How to activate caps lock on Framework 13 AMD?
I want to turn on caps lock on my keyboard. I have tried everything imaginable, but nothing makes it happen. I have searched online and here with no discussion to answer this question. Please help.
Welcome to the forum.
So your CapsLock key doesn’t work? And I believe there is an indicator on the key, that doesn’t illuminate?
When did you get your laptop? I see you tagged this as ubuntu, which version do you have?
You could try running xev or wev in terminal to see if the CapsLock key is being seen. I think ubuntu would be wev, since it uses wayland. You just type or copy-and-paste the following in a terminal & press enter
wev | grep 'sym'
Then you try any key & it will show what is being seen for the keypress.
Thanks. When I tried to run wev, I was told it needed to be installed. So I installed it and then when I ran the command you offered I got a checkerboard pattern across my screen. This didn’t answer my issue, obviously.
If you just run “wev” without any grep it will do the following:
  1. Display a checkerboard
  2. In the terminal window output information about each key press.
  3. Switching to a different windows and back again, then allows you to exit with CTRL-C.
“sudo showkey” also does similar, but without the checkerboard.
Thank you, James. I discovered that because I am using the Omakub customization of Ubuntu, the caps lock key has been remapped.
Thank you, Brian. I discovered that because I am using the Omakub customization of Ubuntu, the caps lock key has been remapped.
