Arch Linux
Which release version?
6/24/2026
Which kernel are you using?
7.1.1
Latest
Which Framework Laptop 16 model are you using?
AMD Ryzen™ 7840HS
Just wanted to know how to do this on the Framework 16, as I have heard that there is jank in regards to eGPU on Linux due to bandwidth limitations.
