I need to recover from hibernation from my keyboard.
Is this possible?
Note: my keyboard is hooked to a hub, which is connected via Thunderbolt hub
Is this possible?
Resuming from hibernation will require the power button to initiate. This is because your system is completely powered down. What you might be thinking of is resuming from suspend where you computer is not completely powered off. This is possible provided the USB hub does not have power removed when sleeping. If it doesn’t and power is present than it can be used to wake a computer in standby.
You need more hubs. Two is not enough.
I can’t wake from sleep through my thunderbolt hub. Its a massive pain.
Update: seems to work 90% of the time now. Not sure why.
