HSI:3 compliance downgraded to HSI:1
Not sure when or why but my HSI security assessment changed from HSI:3 to HSI:1 recently. According to the report I can view in Gnome the following two features are not enabled anymore.
How could I re-enable them? I haven’t found any straightforward way to do that in the UEFI BIOS.
Framework Laptop 13 (AMD Ryzen 7040Series)
AMD Ryzen 5 7640U w/ Radeon 760M Graphics
BIOS 3.18
Debian GNU/Linux forky/sid (updated today, kernel 7.1.3)
HSI-1 Test all passed
HSI-2 Tests
AMD Platform Secure Boot: ! Fail (Not Enabled)
AMD Firmware Write Protection: Pass (Enabled)
TPM Reconstruction: Pass (Valid)
IOMMU Protection: Pass (Enabled)
Platform Debugging: Pass (Locked)
HSI-3 Tests
UEFI Memory Protection: ! Fail (Not Locked)
Pre-boot DMA Protection: Pass (Enabled)
AMD Firmware Replay Protection: Pass (Enabled)
Suspend To RAM: Pass (Not Enabled)
Control-flow Enforcement Technology: Pass (Supported)
Suspend To Idle: Pass (Enabled)
was this ever solved or was a solution found? I have the same issue on 7640u mainboard.
Not solved yet. However, I have found opinions online that this compliance rating framework should not be trusted yet as it is still evolving. Just to be sure I installed Debian stable on the same machine and I magically became HSI:3 compliant again, then reinstalling Debian unstable made me HSI:1 again. So now I’m also inclined not to take these ratings seriously.
alright thanks, this issue is appearing for me on secureblue (fedora) so maybe thats why. Ill just ignore it then.
