I designed a storage box for the expansion cards and screwdriver
Man this is amazing!!!
@AW139_Driver DM me please I would like to send you a BTC tip.
EDIT: I have no idea on how to 3D print or the materials used. I’ve just sent your project to a friend who did it for me.
That turned out great. Does everything fit ok? This was the only version that I didn’t print myself to test.
I really appreciate the offer for the tip, but not needed. Just enjoy it!
Yes it does! Just the top cover needs to be 1mm deeper. But the magnets hold everything together.
My guess is that the magnets I have are slightly thinner than yours. I modeled the holes 2mm deep, since my magnets are about 1.8mm thick. Mine sit just below flush, but it looks like yours ar slightly raised. It’s an easy fix, but it would obviously require a re-print on your end. If you want one, just let me know.
