i7-1185G7 Reached 60W boost. Happy
Thanks @Usernames and @Second_Coming, I did some more testing and my i7-1165G7 only boosts up to ~38W before thermal throttling which was slightly better than stock (edit: IIRC, also now I’m starting to record temps at an ambient temp of 73F), though it’s possible that the replacement mainboard I received (that I’ve been using for several months) may have been prone to the thermal paste pump-out issue. My Arctic Silver 5 tube is years old, though comparing with other pastes, I’m pretty sure thermal performance from AS5 in this die/heatsink setup is far from the best.
I initially was going to purchase a tube from Framework and repaste with that (0.5g of Shin-Etsu X-23-8117) for $5 + $9 shipping + tax. But 0.5g for ~$15 isn’t too great of a value, so I went looking for alternatives. I settled on either Thermal Grizzly Hydronaut (not Kryonaut) or GELID GC-Extreme after reading that those are thicker pastes that are supposedly better for direct die usage (e.g. on laptops) and less prone to pump-out over time. Kingpin Cooling KPx and MX-5 as other notable mentions.
However, I came across this Reddit comment on liquid metal alternatives that sent me down a rabbit-hole on the Honeywell PTM7950 Phase Change Pads. Apparently Lenovo uses PTM7958 (“optimized from PTM7950”) in their Legion 5 Pro laptop
and they have an explanation video here.
So I scoured the interwebs for reviews, and it seems like this is a pretty recent thing. What I found were a bunch of testimonials stating that it provides amazing thermal performance. Application is also simple as it’s just a 0.25mm pad. Long-lasting and apparently used by “automotive customers” as well.
Here’s some data.
TLDR: close to liquid metal performance, without the downsides.
Notable quote from this thread comparing liquid metal to the PTM7950 in a Razer Blade 14:
At the 48W TDP, the results were nearly identical (maybe a 1-2c difference, depending on the core), which is extremely impressive for a non-conductive material.
At the 74W TDP, liquid-metal had a 5-7C lead on the PTM7950 at a slightly lower RPM, but I could not audibly hear any difference. Which, again, is still a very good result for a non-conductive paste (usually this lead is closer to 15-17C when comparing liquid metal with an aftermarket TIM).
Some other notable threads.
Honeywell also makes it in a paste version, though that requires curing time in the application process, and this user reported that
“after being a guinea pig with the paste version i would recommend of getting the pad version instead.”
So, I ended up buying some of the thermal phase change pads – I checked Amazon, eBay, etc. Unfortunately, they seem to only be available through ebuy7 and AliExpress (shipped from China). So I bought from both sites. They hopefully will arrive in ~2 weeks. When they arrive, I’m going to slap these apparently magical pads in and see how they perform in my Framework laptop.
I’m excited and have high expectations for these! If they’re mediocre, I’ll reply here. If they’re incredible, I’ll start a new thread and link to it with instructions. Stay tuned!
fwiw: Best Thermal Paste for CPUs 2022: 90 Pastes Tested, Ranked | Tom's Hardware
I used Kryonaut on my Framework and it was little different to the stock paste. For anything else than special personal usage I just use the newer MX-5. It just works and you can buy it in larger tubes.
Following up on this!
Update support did not send me TIM and instead told me:
The person responded to your ticket didn’t take into consideration of the wording of:
“60w boost” on the 11th gen laptop product page
It wasn’t:
“Up to 60w boost”
The wording of “up to” was in relation to the heatsink & fan’s cooling capacity.
Therefore, the laptop, product as a whole, for the 11th gen was marketed to be perceived that 60w is achievable with every unit as long as operating environment (ambient temperature, humidity, atmospheric pressure) are within spec. It was NOT conditional to silicon lottery.
The keypoint 3 states:
“Dependent on workload and ambient temperature conditions”
Framework | Framework Laptop
Quite agree. The kicker is when queried support state and confirmed expectation is 45-55W not the stated 60W.
Wording is also the same on 12th gen page so I suspect that it will be similar story there too.
I’m not sure even this statement of theirs is true, at least form my testing the cooling system seems to be at its limits at 30-32W.
I ended up “accepting the silicon lottery” explanation because 1 support and I were getting nowhere and 2 the higher quality silicon being more efficient would be much more likely to hit the stated peaks.
Then I would ask…“Given the same wording, does that also mean 12th’s 60w is 'achievable only base on silicon lottery, and is not a promise of achievable performance even when ambient temperature and workload matches that of Framework’s test from nrp?”
i.e. Given the same wording, you can’t have it both ways.
Similar to this case: The law can’t have it both ways: Texas woman given traffic ticket says unborn child counts as second passenger | Texas | The Guardian
Overall, this “60w boost” and “up to 60w boost” needs some improvement on clarify. Otherwise, that’s just intentional ambiguous / deceptive marketing.
Framework 12th Gen buyers beware.
Yes.
I’m just so tired of contacting support over that last 5 months…. I just want a working laptop and this seemed like another hardware problem that could be fixed.
Nothing they say will change the performance I get, at best 47% of advertised. They don’t seem to think it will help sending replacement TIM either. That tells me they either know it wouldn’t help or they only do it for 1185G7s customers.
I have alerted them to the issue with their wording, it is up to them how to respond.
I wonder how the batteries “up to 80% capacity after 1000 cycles” will actually work out…
I’m starting to see a pattern:
  • Next week - Means Friday.
  • July - Means last week of July.
  • Up to 60w - Silicon lottery.
  • …so, up to 80% capacity after 1000 cycles - Best case scenario.
It’s about MVP…minimum viable product.
Like…I don’t know man…if a display panel says max 400 nits…they usually can go around 410-420nits in the centre…all of those that reaches a customer. So, with Framework, this MVP thing isn’t exactly what I’d call striving for excellence.
Really, you can’t sell things (well, Framework can) base on ‘best’ case scenario and place that as product specs.
e.g. When Intel, for example, says X processor has a base clock of yGHz, and boost clock of zGHz…that applies to EVERY unit of that bin / SKU. Not the best case of that bin.
When an SSD is spec-ed as up to 1000MB/s sequential write…that ‘up to’ applies to all units if placed under the same ideal condition, not just the best SSD of the batch.
Framework really need to look at that 3rd 4th screenshot response you provided (above).
The concept of silicon lottery typically applies to unspecified behaviour or characteristic beyond documented specification. So, if “up to 60w” is documented, that’s considered in spec…for every unit sold, and should not be further subjected to silicon lottery. If I want more than 60w (undocumented), then sure, park that to silicon lottery.
I think if the language used makes it clear “this is expected in ideal conditions only” it is O.K. IMO but it’s not good when wording is misleading, intentional or otherwise.
When the deviations from stated performance in ideal conditions strays more than 10-15% from marketing materials you are just lying.
Reminded me I missed the first response before they did the 180*. Will add it now so it will be 4th SS shortly.
The stated conditions were temperature and workload. Silicon lottery is not one of them. As such, if those two conditions are met, then that’s all there is to what’s considered as “ideal condition”.
Mind you, maybe this is a case of internal miscommunication. Maybe this needs to be escalated within Framework Support?
Exactly. The issue is the disparity with the wording, real world performance and supports response.
Completely possible and I hope the reason. I actually think they are exposing themselves to legal action as things stand.
