I’m absolutely in love with the whole idea of the input modules! <3
I just have one open question / concern: What’s the connectivity situation of the modules for the bottom row?
It looks to me like the connectivity for both rows share contacts along the middle of the input deck.
So if a module on the top requires connectivity in that column, the bottom row module can’t get any?
Currently the only bottom row input module that needs a connection is the trackpad, and for that, connectivity seems to be reserved under the keyboard.
And if I saw it correctly, the numpad even blocks / uses both pogo connectors? So you can’t use any connected modules below it?
So if you’re using the keyboard, numpad and trackpad as a daily driver, you won’t get any expandability at all without removing the numpad?
That seems to be quite limiting and not reflecting the flexibility that I thought it would bring.
I’m not sure if there’s still room for change, but what I would wish for as a minimum would be that the numpad design should be altered to keep one connector position free for bottom row modules.
Because my account is too new, I can’t post multiple images, so have them as a collage.
1 Image of pogo connector row from official announcement
2 Image of pogo connector row from LTT video
3 Numpad input module covering up both connector positions
4 Two pogo connectors under the numpad location
